Finally bought a 95 LS - Bad news needs rear differential - Where to find one
Old 05-12-14, 01:24 PM
timmy0tool
timmy0tool's Avatar
i would think even if the input shaft seal was leaking only a small amount of fluid would be missing and not completely dry out. it is normal to have metal shavings in the magnetic drain bolt (looks like sludge or mud).
metal chunks on the other hand, are bad news! gl with the replacement!
Old 05-12-14, 08:14 PM
sha4000
sha4000's Avatar
In for final results and take some pics for future searchers of this problem.
Old 05-12-14, 09:05 PM
Shmee
Shmee's Avatar
Depends on the cause of the leak. If the seal just simply "wore-out" then usually you won't starve a diff for fluid unless the input pinion is offset well below the center line of the diff.
Now if there was a lot of bearing play at the input, and THAT cause the leak the. It would be pretty easy to starve a diff for fluid in a short period of time. Of course there would be a VERY obvious noising coming from the diff well before the failure point, and you'd be able to feel some pretty wonky things going on at all times when driving.... But considering the core demographic these cars are coming FROM, and the fact that there are two around me driven by people 80+ and look like they drive/park by brail.... It's possible for such crazy things to happen!! lol
Or you could have the owners kid/grandkid out hooning doing burn outs and nuetral dumps!
Old 05-13-14, 04:49 AM
Nichles3
Nichles3's Avatar
I will take some pics. You can tell that it has been leaking for a while and definitely from the front of the input shaft (where the drive shaft is connected) . Once I get the old one out I will open it up.
Giorgio13
21
04-19-19 05:52 AM
Johnhav430
07-22-17 12:16 PM
Legender
12-15-13 03:45 PM
RA010623
19
07-25-12 01:28 AM
SLVRGS
GS - 1st Gen (1993-1997)
06-20-04 03:16 PM
Quick Reply: Finally bought a 95 LS - Bad news needs rear differential - Where to find one
