remove the screw on the top... then pull evenly straight forward and the unit should pop out...
I just did one on my 99... pretty easy when you've done it once and know what to expect.
There is no screw.. I am talking about the small amber marker light that is on the side of the fender."or bumper" since the bumper wraps around.... . At least I see no screw anywhere on the light.
easiest way is to go in from the fender well side. you can just turn the wheel to one side but i find it easier to just remove the wheel, unfasten the fender liner screws, and go from there. then it's a simple twist counterclockwise and the bulb holder is off while the lens remains on the bumper. i highly suggest you replace both bulbs on each side! the other is bound to burn out soon.
