Question about changing cam seals on 98 with VVT-i
#63
I actually used some carb cleaner even though they say don't use it because That's the only thing I had around. The other front bearing cap came off easily Though. I'm thinking of just taking the intake cam out and leading the exhaust one in there tomorrow.
#65
Yes the intake cam is the only one the really needs to be removed but if you just follow the manuals instruction it directs you to remove both as if you would be servicing the exhaust also. You do have to lift both of them out initially since the gear teeth are meshed but you can then sit the exhaust cam back in there.
#66
This is what I found on the drivers side head where the valve cover gasket goes. I was snapping picks to keep track of all my work and noticed it. Will this mess up the gasket seal? If so how does anyone suggest I file it down?
#67
I'm having the same issue as others before me. I can't get the TB on the passenger cam. I remember when I helped/watched do the first TB at 120k that the right cam actually moved clockwise but not actually turn when you pull on the ratchet. This time however it turns but doesn't actually remove the tension. Any ideals?
#69
I've been turning the Broken bolt from the back and make a Lil progress but it's slowing going. The needle nose pliers keep slipping though. Is the a better method with this much of the bolt exposed?
#72
as for the gouge in the gasket mating surface, just file off whatever exposed excess metal there is but don't go overboard and take off too much metal. the new FIPG should go into the spot and still form a good seal.
how is the rest of the job coming along?
#73
The valve cover actually has a rubber gasket but I will put some FIPG under that spot to help it seal. The job is almost done considering I had to take the belt back off the passenger cam to remove the pulley and front bearing cap to get that bolt off from behind. I got it all back together and the timing is still spot on though. I just have to install the valve covers, fan coupling, fan, radiator and air box. Then I will put some seafoam in the oil and let it run for about 15 minutes, drain it and put some mobile 1 synthetic in the engine.
#75
First I want to say Thanks to Sha4000 for undertaking such an adventurous and complex repair and for asking the critical questions!
I also have a 98 VVTi in my GS and will be tackling this same Cam Seal replacement very soon I too have the FSM from Toyota / Lexus and I agree that the head removal portion, that explains the cam removal process, leaves much to be desired in some of the key details that were brought up in this thread. I have read this portion of the FSM a number of times and had wondered if both cams were in proper servicable alignment when the 50deg past TDC. Now that I know this ahead of time I won't be caught when I attempt to complete this project over a weekend as this is my DD.
I still am a little fuzzy about the drivers cam and the process of turning it CW or CCW to get the arrows aligned to place the service bolt? I would really love to speak with you over the phone about your experience.
Please text me at your earliest opportunity at 6787709017 or leave your number here and I will reach out.
Best, David
Best, David
