new to ls400 code 55 and 71
Old 05-19-14, 12:33 AM
297xxxl400
297xxxl400's Avatar
Default new to ls400 code 55 and 71
Thanks in advance guys ok i fixed my check engine light bulb and i have code 55 and 71 knk sensor and egr circuit
So I've read that cleaning the egr and throttle body along with the egr modulator can take care of code 71 got the code 55 are they like the mk3 supra with the knock sensor wire being the problem or should i swap the sensors out thanks a lot for any help
Old 05-19-14, 06:07 AM
python
python's Avatar
code 71 can be a vacuum leak within the egr system
code 55 is a knock sensor failure, replace both sensors..the connectors and if u haven't replaced the starter, now is a good time.
Old 05-19-14, 06:18 AM
sha4000
sha4000's Avatar
Like python said if you have to replace those knock sensors get the starter done too since you have to take the manifold off.
Old 05-19-14, 10:43 AM
297xxxl400
297xxxl400's Avatar
Default ok so changing the knock sensors
thanks in advance do before tearing into her are the gaskets metal reusable or do i need new ones and any things to look out for stuff i don't have to remove but I'll possibly think i do and make the job harder if you know what i mean things i might break i need this to be a smooth job i just got the car and i need to smog it
Old 05-19-14, 12:51 PM
steve2006
steve2006's Avatar
If you have to remove a gasket replace it with a new one,costs a little more but saves another strip down if a reused one fails to reseal.
DeanWeen
GS - 1st Gen (1993-1997)
10-09-18 04:08 PM
islexusred
01-29-14 07:50 PM
Slvr surfr
11-09-13 06:08 AM
squeekyM
09-26-06 07:36 AM
Quick Reply: new to ls400 code 55 and 71
