Help: 2000 LS400 Nak to Aftermarket Conversion
#31
Looks like on the NAK diagram the AMP+ wire is pink with a blue stripe. its on pin 6 on the A plug though. I read through that thread. Its for the Pioneer system unfortunately. Doubt it will work but worth mentioning I guess.
And i wholeheartedly agree with Kansas. Your AUDIO installer can't figure out an AUDIO wiring diagram? Take it to best buy. Seems they have more qualified installers. -__-
#32
i have a different looking diagram but it shows the same connections.. pin 11 at the radio, pin 6 at the amp. I think the wire color is probably most important. I show pink blue at the amp side, but on my diagram it says pink black on the radio side. Either way, its the only pink and striped wire I see on the diagram, so it should be picked out quite easily. The main question is whether or not the new HU can send a digital signal to the amp like bornking was told it would need. I don't claim to know how any of this (Nakamichi) works so take all of this with a grain of salt. Make that a silo, or whatever salt is held in
#33
Ok so i opened up my console and took pics
looks like the first audio guy did exactly what you guys said, he connected the power control wire from my deck to the pink/blue wire on the a bundle. see pics
#36
Couldn't wait. I solved the issue!!!!
The blue/pink wire was CORRECTLY connected to my power wore from my deck.
Then I noticed he connected the ILLUMI wire from my deck to a green wire on my car's harness.
Since the Illumination didn't change on my deck with my car, i thought he may have connected it to a speaker wire by mistake.
I disconnected the illumi from the green wire PRESTO the subwoofer works!!!!!!
#37
YoungNas
07-30-18 12:02 PM
KaLiBLeeK
09-10-14 07:22 PM
