How to modify the tail lights failure sensor for UCF20/21
Old 09-02-15, 09:26 PM
  #46
Yamae
Yamae's Avatar
Originally Posted by goyal1
I have 2002 LS430, I have same problem with "Tail Light Failure". All bulbs are checked and three replaced. No failure indicator unless I put in DRIVE mode (reverse or forward). The "Tail Light Failure" light comes on as soon as I put in Drive.
Please advise.
Toyota has completely changed the design and the one for a LS430 is totally different. The function is included in the other unit called a multiplex rear junction computer. I once have seen the way how to modify the circuit in the Net but I can't find it today.
Old 09-02-15, 10:23 PM
  #47
Yamae
Yamae's Avatar
I found it.
http://minkara.carview.co.jp/userid/...3213/note.aspx
It's not me who succeeded and all I can do is just to introduce you above. You need to understand above asking for a good help to someone who is capable to understand it.
Old 01-09-16, 01:13 PM
  #48
RugbyDad
RugbyDad's Avatar
Installing my chasing tails and this worked like a charm. 2000 ls400.
Old 01-09-16, 01:25 PM
  #49
Swint
Swint's Avatar
Where did you get your tails from?
Old 01-10-16, 03:02 PM
  #50
RugbyDad
RugbyDad's Avatar
CentralPine.
Old 02-05-16, 08:14 PM
  #51
Yamae
Yamae's Avatar
I found it.
I posted my own method which is simpler and easier for earlier UCF31 and 31. It is at the LS430 forum below.
https://www.clublexus.com/forums/ls-...ml#post9345251
Old 01-08-18, 09:33 AM
  #52
Torkasmax
Torkasmax's Avatar
Just got my, new to me, 2000 Platinum on the road after 90K service (@102,800M). Installed led tail lamp bulbs, clipped the described resistor. This worked as advertised.
Official Thank you to Yamae!
Sorry to drag up a thread this old, but thanks was in order!
TORK
Old 01-08-18, 11:54 AM
  #53
Scraape
Scraape's Avatar
glad i stumbled upon this thread, ive had the tail lamp failure notification coming up as long as i've owned the vehicle.
I'll have to try this out to get rid of it, plus i plan on getting chasing LED tails at some point
Old 11-24-21, 12:16 PM
  #54
RA40
Super Moderator
RA40's Avatar
This was jogged by another thread which had me curious. Is there a means to modify this sensor module so that it retains proper function with LED type replacements? Would this render the module ineffective if going back to incan bulbs?
Old 11-24-21, 12:19 PM
  #55
Received 2,846 Likes on 2,405 Posts
The mod makes it so the sensor box does nothing but pass power through it, no matter the bulb used it won't current sense and tell you if any are not working.
Old 07-23-24, 06:35 PM
  #56
Redenergy
5th Gear
Redenergy's Avatar
Default 08 ls 460 tail lamp failure notice
my tail lights reverse lights license plate light not working prior to that headlights went out help if u know something please and thanks everyone
Old 07-23-24, 10:11 PM
  #57
Yamae
Yamae's Avatar
You need to ask your question at the LS460 Forum since this is the LS400 Forum and members here are not familiar to LS460s.
Abernoots
04-18-18 02:06 PM
JRGS300
07-25-14 12:04 AM
bossladee
SC- 1st Gen (1992-2000)
11-03-13 04:41 PM
MySCSucks
09-15-12 01:44 PM
CallMeLEX
05-07-12 10:51 PM
Quick Reply: How to modify the tail lights failure sensor for UCF20/21
