2000 LS Foglight mod. (hid)
Ok, I messed around with the other projector today and have them finished 80%. I just need to mess around with aiming them.
here are some pics.
driver side projector in, other side just modded with 9005 bulb.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_195152.jpg)
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_195633.jpg)
Passenger side in.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_201248.jpg)
Here is the cutoffs with both installed, I have some tweaking to do.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_201311.jpg)
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_201806.jpg)
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_203210.jpg)
low beams only, fogs off.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_203220.jpg)
so far im very happy with the light output.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_203826.jpg)
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_203142.jpg)
I still have to install the wiring harness and relays, as well as the wires for the Bi-xenon solinoid for the highs. So right now these are being run off the factory harness. I was too excited to see what they looked like.
here are some pics.
Passenger side in.
Here is a little how to, or what i did. for those that are interested.
stock fog
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_170852.jpg)
heat gun.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_170943.jpg)
Heat around the front of the fog, where the lens goes into the housing. GO EASY! slow and steady!
and dont forget about this screw.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_171026.jpg)
gently pry the lens off, if it gets difficult use more heat.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_171425.jpg)
Here is the glare thingy that gives us ****y light output. remove this.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_171635.jpg)
Now these two screws
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_171759.jpg)
Now these two screws. then you need to loosen the adjustment screw on the back until the bowl comes free.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_171834.jpg)
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_172104.jpg)
Here is the projector.
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_172301.jpg)
the shroud need to come off, it doesnt fit.
Thats better!
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_172351.jpg)
Now things are going to get scary for some of you. After this you are committed.
We need to modify this.
stock fog
heat gun.
Thats better!
![](http://i840.photobucket.com/albums/zz328/Rhansen1987/Mobile%20Uploads/20140703_172124.jpg)
