OMG!~! My exhaust is TOOOOO LOUD!
Guest
Posts: n/a
LOL OMG!!
It's so loud everythign in the car vibrates and you can't even hear your self think!!!
I took it to the shop to have the center resonator put back in and I told them to just leave it open after the cats and the centor resonator!!
JEEZ!!
I did the 0-60 and got a 8.02!!! I think my rear mufflers were clogged and reduced performance!
I drove by some integra guys (racers) and they couldn't figure out where the sound was coming from! They were all confused looking around.
Here's a picture..I don't know how long I can deal with it..it's REALLLLLY loud!
JEEZ!!
I got a better mod that I've been trying for about a year now. Not only did I take off the whole exhaust pipe, but I also removed the resonator, the y pipe, the cats, EVERYTHING. Man, you should hear that thing now, DINK. Lemme know if you wanna try this and I can hook you up with a diagram too. late
Guest
Posts: n/a
I've got a video clip - but I don't know when I can get it online.
Lextreme - It's MUCH louder than your car..you can't really have a conversation with anyone.I'm really paranoid to drive it because anywhere I drive EVERYONE's heads turn. i had to find the sweet spot on the freeway at a certain RPM so it was slightly quieter as a cop passed me - I got reallly scared. LOL
Anyway I posted as reply because I noticed the RPM's move VERY differently since the exhaust is kind of open now. The move up very fast and drop the same.
Search Function Inc.
I got stopped a number of times for my current exhaust sound, and it used to be four times as loud without mufflers. That's why even if I do a turbo setup I'd like it very descreete.
Super Moderator
dood-
Lee's car is MUCH MUCH MUCH louder than Lextreme's car. It's almost in the range of area51's drag SC, but not quite.
I got the video here...just need to host it someplace. i have an idea of how to get it up in the shortest amount of time. will get back to u guys on that.
Lvan,
If you don't like the sound, why don't you just have some new mufflers added? Or maybe just put your old mufflers back on. FYI, the 0-60 times on the 90-92 LS was in the 8.8 second range, when new of course. I'm guessing your better times were due to back pressure being reduced by removing the mufflers. If you keep the mufflers off for an extended period of time, you will begin having problems as your car is intended to have a certain amount of back pressure, which you lack with your current set up.
Guest
Posts: n/a
OK here's pics of the LOUUUUD setup and here's pics of the new setup with a 'blue streak' glasspack after the centor resonator.
Can someone explain why I get a loud whistling sound after 3000 RPM?
It sounds like turbo pressure or something.
Why would you leave the pipe disconnected at all? Hit a good bump or bottom out and you may lose most of your exhaust system. Not to mention that exhaust fumes can work their way into your car. I'd connect the system back to stock and put the glass packs where the mufflers were if I were you. You'll get an even better sound without having to worry about the fumes & your performance shouldn't be less than what you have now.
Guest
Posts: n/a
tenpointed - Thanks for the concern. My plans are to just have a good sound without spending $200 for dynomax mufflers or whatever the case. I'm not too worried about anything else.
Have you spoken to 'jbrady'? You seem like you know alot about cars, as does he.
Celsior - I don't have access to a mic, but mezoom! has some clips I'd like to get soon and post.
