Check Engine Light just Came on !
All,
The CEL on my '95 just came on last night. I'm going to have the code(s) pulled out tonight. Anyone here with service manual can help with decoding it ? Thanks in advance !
which code do u need? I just got a Toyota-Lexus CD. Check engine light ccould be a lot of things. Specific code will help. Give me your fax number. I have the article for you.
tenpointed, you were right. The code is P02430 (if I remember correctly) which according to Autozone is catalytic converter operating below threshold, bank 2 (or something like that). So, it's the downstream O2 sensor on the passenger side.
92lexus, can you confirm this ? Thanks.
Tom, are you sure that code is right, I am unable to match that code with my code sheet. Let me know if it is right cause im curious now too.
Someone else who has codes is Lextreme, he replied to you on this post as well, check with him on your code too, he may have a newer source than me.
good luck
92lexus out
good luck
92lexus out
nicos1
10-08-07 12:44 PM
