No Heat or AC....HELP! 91 Ls400
Thought I had the Lexus all ready to go, as my daughter was off to last year of college a few weeks ago. About half way through the trip she calls me and said the AC stopped working and none of the lights on the heater/ac control panel were working. No blower for heat or AC. We were on our way to meet her since we needed two vehicles for all her stuff ..... upon inspection I noticed the clutch was not engaging, but looked like it was trying to move. Belt was spinning ok on pulley with no noises.
If the clutch seized up , could it have simultaneously blown a fuse or relay. Since the hot weather is done, I just need to get her heat system / blower running for winter. I can deal with AC in the spring.
I assume she should be ok to drive home 50 miles as long as belt is spinning freely?? She is coming home this weekend and I need to get it resolved!
Any suggestions appreciated!
Thanks,
Paul
the AC was new & installed about 4 years ago by me.
Thanks,
Paul
Paul, first reach down and try to turn the compressor by hand just to see if it frozen up, then since your control panel is dead, I would start with fuses inside and under hood, and since it is easy to remove the panel, check your plug in connections, burned wiring and damage if your fuses all check out ok.. no quickie that I know of..
Hey Billy,
Thanks for the reply! My daughter is home with the Lexus today and I was able to do a little bit of troubleshooting.
First off, as you suggested I was able to turn the clutch with my hand, but the pully is definitely starting to make some noise like the bearing is bad.
Secondly I did find the blown 15amp Heater fuse inside under drivers side . Replaced the fuse , but every time the AC is turned on it blows.
My question: Is there a fuse or relay ( i didnt see any for AC under hood or drivers side box) specifically for AC that I can pull so it cannot be turned on, so she can at least have the heater /blower running for heat. No need for AC until May lol. I just dont want AC button getting turned on by accident. Or i guess if there is not a specific fuse, can I unplug electric connection to AC compressor???
Just want to make sure this is independent and won't affect anyything else , short of AC pulley seizing up and breaking the serpantine belt. She is only home until tomorrow, so I have to have a move quickly.
Thank for any others that may have input for me.
Paul
Paul
yes Paul, just unplug the compressor. I have never heard of that affecting anything else.... what I meant by reaching down and turning the compressor, was the head, not the clutch. but I am sure yours is frozen up because of it blowing the fuse. the only danger you or her will have to watch for, is if the bearing in the clutch goes bad and breaks the belt.... tell her if the temp gauge starts going up, to pull over and turn the motor off or it will be ruined. DO NOT try to make it anywhere.. call a friend... find someone for her to call just in case. (police if necessary, they should get her to the station/somewhere safely).. good luck
Billy,
I pulled the belt an was able to spin the pulley freely, but it's making noise with some play front to back. Bearing is bad. I was able to pull the AC relay in the fuse box under the hood. Now the heater is blowing fine. Question is what was causing the fuse to blow if pulley spinning freely. It must be when clutch tries to engage. I'm thinking I will pick up a reman and swap out in next week or 2. At this point its drivable with heat and she can get back to school.
Thanks for the help, Very much appreciated!
Billy,
