just did timing belt engine sounds kinda like a diesel please help
Old 09-27-14, 09:58 AM
randal
randal's Avatar
Ok, well there is your problem. You have your cams both lined up but the crank is at 20 degrees Before TDC. It should be at 0.
You are going to have to release the tensioner, pull the belt and re-align. Make sure that when you re-do the belt that you rotate the crank at least 4 times to verify that the cams still align with the brackets and crank is at 0 degrees (TDC). Remember, the cams will only align every 2 revs of the crank because it is a 4 stroke engine. You will then be good to go.
Old 09-27-14, 02:35 PM
cobalt91
cobalt91's Avatar
Couldnt help but notice the thermostat. Are the bleed holes clocked correctly? I thought on would need to be at twelve o'clock.
Old 09-27-14, 03:58 PM
billydpowe
billydpowe's Avatar
thanks randal, I was frustrated, I just take it for granted that DIY's have a basic understanding of engines, and that is the wrong approach... and yes cobalt 12 is right
Old 09-27-14, 05:01 PM
randal
randal's Avatar
The thermostat bleed hole is called the "jiggle valve" and covered in this thread -> https://www.clublexus.com/forums/ls4...gle-valve.html
BTW, Viper, nice pics. You could almost just loosen the tension on the belt, pull it off of the crank while leaving the cams in place, turn the crank to 0 degrees and reinstall the belt on the crank. Sometimes its not that easy but you could try.
Old 09-28-14, 10:45 AM
viperrgh2
viperrgh2's Avatar
Did it again today everything was lined up it ran smooth idled low ran great and then after like a minute started miss firing and running like **** again
Old 09-28-14, 10:48 AM
viperrgh2
viperrgh2's Avatar
Miss firing 3 5 6 and random
Old 09-28-14, 10:57 AM
randal
randal's Avatar
So you realigned the timing belt, verified the timing as correct, buttoned it back up and it ran fine for a minute, then back to dieseling again? If that is correct, then I am afraid you are going to have to verify the timing again just to make sure the belt is not jumping a tooth or three. Maybe something wrong with the tensioner holding properly. We have also seen several instances where the crank pulley key was not aligned and just got 'mashed' back in. That causes a slippage as well.
Old 09-28-14, 11:15 AM
viperrgh2
viperrgh2's Avatar
Nvm fixed it was a combo of belt which was fixed this am and 2 plug wires needed to be switched.. i need to stop working on cars at 11pm after workin since 6 am... ty all for the help much appreciated
Old 09-28-14, 04:49 PM
cobalt91
cobalt91's Avatar
Glad to hear its fixed. Which plug wires were crossed?
Old 09-29-14, 10:54 AM
brybo86
brybo86's Avatar
LOL sounds like something I would do...
glad you got it all back together, correctly
Old 09-29-14, 05:41 PM
Yamae
Yamae's Avatar
Congratulations on your success to fix. Hoped my advise was effective.
1killerls
46
08-15-11 12:25 PM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
diverchris
09-10-10 02:05 PM
Quick Reply: just did timing belt engine sounds kinda like a diesel please help
