Has anyone tried this ATF??????
Old 10-12-14, 10:17 PM
Finn
Finn's Avatar
Originally Posted by steve2006
In the UK the Toyota type IV costs £12.00 ( $18.00) a liter and I still buy it at that price just for complete piece of mind.
Steve, check this link:
http://www.ato24.de/schmierstoffe-lu...a.html#/page/1
Old 10-13-14, 10:22 AM
Bill Dowd
Bill Dowd's Avatar
if you want to use a synthetic ATF Mobil one and Max life both work ok in a 90 Lexus 400 I have a 91 LS and have 318,000 miles on the same trans using M 1 changing it every 30k flushing it thru my trans cooler. My 1986 Toyota Cressida trans went 529,000 no problems with Mobile one fluid. I am now using Max Life synthetic AFT for my power steering which is original for cost buy it at Wall Mart. Toyota type 4 will work just fine just change it at around 30k that includes m1 if you want you trans to last. My goal is 400,000 to 500,000 on my 1991 Lexus LS keeping everything original I also go 15,000 miles on engine oil changes using M1 and no problems no oil burning I would like to see a Mercedes or BMW do that.
Old 10-14-14, 07:06 PM
timmy0tool
timmy0tool's Avatar
i actually recall that mazda also uses the same ATF as toyota type-IV as the aisin makes their transmissions as well. if you can get it cheaper at the mazda dealership too, go for it. around my area a bottle of type-IV can be had at less than $5/quart.
as for the rear end, that is not as sensitive to OEM fluids as the tranny. any synthetic 75w-90 gear oil will suffice.
Old 10-14-14, 08:52 PM
Yamae
Yamae's Avatar
Yes, you are right regarding the ATF type-IV, but regarding to the rear end, I don't think so.
Old 10-15-14, 06:36 AM
python
python's Avatar
ive been running redline..before that Valvoline 75w-90. ive had my car for 10 years and 70,000 miles.
Old 10-15-14, 10:46 AM
timmy0tool
timmy0tool's Avatar
please explain more yamae. i don't see how the differential would be sensitive to gear oil, but i would love to hear your input. i know the OEM stuff is not synthetic, so upgrading can only benefit.
Old 10-15-14, 09:28 PM
Yamae
Yamae's Avatar
It should be the hypoid type of gear oil and API GL-5.
Old 10-16-14, 05:30 AM
python
python's Avatar
I don't know of any synthetic gear oils that aren't gl-5. gl-4 is for older gear boxes to protect bearings that are made of certain metals that gl-5 will ruin.
Old 10-16-14, 08:17 AM
python
python's Avatar
after checking they do make syn. gl-4 gear oil
Old 10-16-14, 06:49 PM
Yamae
Yamae's Avatar
Some manual transmisions require synthetic GL-4 and oil companies are supplying it. Don't use GL-4 for our precious cars.
Old 10-17-14, 10:53 AM
Shmee
Shmee's Avatar
Like anything, read the owners manual and only run the specified fluid type stated in the back.
unless there has been an update since printing, it is always a bad idea to deviate from the engineer prescribed fluid types. do so at your own peril.
Old 10-17-14, 09:39 PM
python
python's Avatar
fluids have come a long way since 92
sherlock19
GX - 1st Gen (2003-2009)
05-19-18 08:10 AM
Michael
13
11-24-13 08:59 PM
goldlexus9
Maintenance
10-31-08 11:06 AM
Mike
RX - 1st Gen (1999-2003)
12-09-07 11:23 PM
HotBoy
Maintenance
12-30-03 09:09 PM
Quick Reply: Has anyone tried this ATF??????
