Bought a 99 LS400 - Dealer quoted $6300 in maint/repairs - Should I keep it?
Old 10-18-14, 03:48 PM
  #31
billydpowe
billydpowe's Avatar
Originally Posted by UniqueCopy
It seemed a little high to me, but experience from many years of Toyota ownership has me convinced it's worth a little more for the red and white box
So you did the cam seals, which requires removal of the cams? That sounds like a huge job. I'm wondering if it'd be better to hold off on that until the need is there? Or is it much easier with the front of the engine apart?
unique, my 99's have 242560 & 186371 miles on them and I would NOT replace the cam seals unless they were leaking..... I have had 5 99's before I settled on the two I have, and none have had a cam seal leak...
I replaced my first pan gasket at 14, been working on cars ever since, had my own shop for 30 years, retired 18 years ago in 96, so I am over 80 today, and my thoughts are, if the cam seals are NOT leaking leave them alone........ if you are hunting for work, I would recommend replacing your motor mounts, I would bet they are in two pieces like mine were.... and my tranny mount also SEE
Attached Thumbnails Bought a 99 LS400 - Dealer quoted 00 in maint/repairs - Should I keep it?-100_0703.jpg   Bought a 99 LS400 - Dealer quoted 00 in maint/repairs - Should I keep it?-100_0705.jpg
Old 10-18-14, 04:39 PM
  #32
sha4000
sha4000's Avatar
The TB kit is not made by Toyota, It's comprised of parts from the OEM manufacturers of said parts. The AISIN 021 Kit has all the same parts that the dealer would install. The price is just not marked up.
http://aisin.mycarparts.net/
The cam job is difficult but like Billy said if they are not leaking when you go in to do the TB/WP you can leave them alone. It's recommended for the 97 and down engines because the are so easy to change. I did my cam seals in May of this year at the same time i did the TB/WP since I had oil literally run out of the bottom of the engine.
Originally Posted by RugbyDad
Well if you notice I didn't say get THIS kit. I said get everything in this kit. I meant to source the parts, like sha outlined. I will be doing the exact same in 8k miles. Didn't mean to confuse or mislead (especially with the 97 parts, Sewell automatically saves whatever vehicle I was recently browsing under).
No confusion at all I was just giving another less expensive option that I took personally. I research everything to death before I even need to do the repair. So I not only find the least expensive online dealer to go with for OEM and aftermarket parts.
YODAONE
09-22-18 06:22 PM
Patsum
09-04-11 09:44 AM
bad co
Chicago Lexus Club
10-31-09 04:17 PM
dantampa
16
08-25-09 05:37 AM
Quick Reply: Bought a 99 LS400 - Dealer quoted $6300 in maint/repairs - Should I keep it?
