I have a LS400, 1993, can anyone tell me what type of bulbs I need for my gauge cluster?
I noticed there are two different bulbs.
Thanks for your help.
Den
If you do not have an owners manual they are available for free from Lexus Corporate.Call 1-800-255-3987.While there give them your VIN number and ask if there are any open recalls or service campaigns.Sewell Lexus is also very helpful and can give you the exact part number for your bulb,1-877-523-3311.Good luck.
I don't know if the LS400 PRNDL bulbs are the same as older Toyota products, but some of the older cars had the bulbs which were simply the smaller ones with the two bendable leads that came off of them. The leads were wrapped around these little plastic sockets which then plugged into the dash circuit board.
The burned out bulbs could have their leads unwinded from the little sockets, and you could simply replace them with a similar 12v bulb from radio shack, which would run just a hair over a buck.
Burned out rear bulbs sign kept go on. I replaced all tail and brake bulbs. Still on.
Turned out 1 bulb among the 5 in the high center brake light cluster burned out. Put in a T10 LED. Sign still goes on.
Had to buy a 2825 incandescent bulb T10 base, 5W per Lexus manual, 10x for $8 on eBay. These bulbs all have to be 5 W each. Similar bulb 194 3 W will light up but the burned bulb signal will go on.
