Power Steering Fluid won't move (flow), What could be the problem?
1996 LS400 237K miles. Cleaned the power steering Solenoid screens 6K miles, and 6 month ago.
In the past two weeks, the power steering pump made a very loud noise. The power steering fluid won't flow. I thought the power steering pump was bad, resulting in no-flow of the power steering fluid.
I bought a reman power steering pump form The Advance Auto Parts store, replaced the old pump, added the power steering fluid, Nothing changed at all-. Started the engine, the newly-installed power steering pump still made very loud noise, and the power steering fluid won't flow at all. I turned the steering wheel full-left, full-right, the fluid still won't move (won't flow), and the power steering pump made a loud noise.
Assuming that the newly-installed PS pump is a good one, what other things could prevent the power steering fluid from moving (flow)?
The power steering solenoid screens were cleaned 6K miles ago.
Thank you.
Thank you.
Correct me if I am wrong, but To the best of my knowledge, the 95+ models didn't have the solenoid screens..?
It sounds to me like you got another faulty pump! Although rebuilt P/S pumps from auto parts stores are usually pretty decent, you may have gotten one that was done to sub-par standards.
My car was doing the same thing and what I did to fix it was took it on a high way on ramp with a couple turns and got the revs to 4000 -5000 and did the turns and it felt like something popped and my power steering came right back. It was the weirdest thing but it's been working fine ever since!
I thought the there might be no fluid inside the the power steering pump resulting in that the pump had nothing (except the air) to pump, so the ATF won't flow.
I loosed the ratainer nut that connects the high pressure hose to the pump, let ATF leak a little bit, so the ATF could saturate the pump, then tightened the nut.
Started the engine, and the ATF began to flow.
But there is still noise, the noise might come from the PS pump, or alternator, or other moving bearings. There must be a bad bearing, since it burned the serpentine belt.
