timing mark confirmation
Old 12-25-14, 10:50 AM
sha4000
sha4000's Avatar
No need for FIPG if you have the gasket.
Old 12-25-14, 11:13 AM
SynicalVip
SynicalVip's Avatar
Sound good! Just want to make sure, those damn FIPG do get messy lol
Old 12-25-14, 02:40 PM
randal
randal's Avatar
I try to stay away from FIPG myself, just because it is so messy. But it does form a good seal when used correctly. Make sure you tighten the pump bolts in a crisscross pattern and torque in steps(I like taking it up in three increasingly higher torque levels until the final). That will ensure a good, even seal.
Old 12-26-14, 08:11 AM
SynicalVip
SynicalVip's Avatar
So I guess it seem like the water pump isn't machine right to where it sit flush up again the motor. Now to return it and get another one 😑
Old 12-26-14, 03:59 PM
sha4000
sha4000's Avatar
Where did you get the TB kit from and what brand is it?
Old 12-26-14, 06:29 PM
SynicalVip
SynicalVip's Avatar
I didn't buy it I'm doing the work and it was a kit from pepboys smh! Told em to go with aisin kit but nope didn't wanna listen lol. Got new pump and it's not leaking anymore. Now just need to put the belt on and then it's good. Hate putting the belt on lol any tips and tricks to slide it on the cam easier?
Old 12-26-14, 09:27 PM
sha4000
sha4000's Avatar
Oh I thought you were doing your own car. Anyway I bet they will listen next time. I have a 98 so it might be different for your car but my cam kept jumping some teeth and it took me a long time to get that tight belt on. I had to apply the right amount of slack to the right hand cam to get the inside part of the belt on the left cam and then I pushed it the rest of the way onto the grooves. Then I had to take the belt off again for another reason. I ended up putting it on and then torquing the tensioner which made it much easier.
Old 12-27-14, 07:39 AM
SynicalVip
SynicalVip's Avatar
I myself have a 98 as well lol. All I got left to do is put the belt on like you said the cams keep jumping some teeth when I pull the belt trying to put over the right cam. Guess there is no easy way at all just gotta keep doing until able to.
Old 12-27-14, 01:10 PM
sha4000
sha4000's Avatar
You just have to be patient or do like I did and release the tension, put the belt on and then bolt the tensioner back on.
Old 12-28-14, 08:05 AM
SynicalVip
SynicalVip's Avatar
Got the belt on etc and everything put back together. Started up the car, and it starts but when I turn it off and start again I get code p0340. 😕😑
Old 12-28-14, 10:29 AM
SynicalVip
SynicalVip's Avatar
Figuring out the issues at the moment, look like the Damn timing jump
Old 12-28-14, 03:12 PM
sha4000
sha4000's Avatar
Are you sure that you plugged the camshaft position sensor back up? Or that you havent damaged it or the wires?
Old 12-28-14, 05:40 PM
SynicalVip
SynicalVip's Avatar
Yes everything was plug back up correctly etc and it is the timing that jump. I redid it and everything is good now 😊
YODAONE
19
02-02-17 09:11 PM
CARSNBIKES
Performance & Maintenance
03-27-15 06:45 PM
crizq0
01-30-14 10:17 AM
lex2001
09-21-10 03:48 AM
Och
22
02-02-08 11:59 AM
Quick Reply: timing mark confirmation
