HELP-car cutting off while driving
Old 01-19-15, 03:35 PM
  #46
randal
randal's Avatar
Originally Posted by LS400BOY
So you you say jumper the fp and b thats jump it with jumper cables to the battery correct just making sure
No, no, no....leave the jumper cables in the trunk! You don't need or want them for this test. Just take a small, short piece of wire (16 or 18 gauge, whatever you might have laying around) and connect the two pins in the test port connector together. They are only separated by inches...if that. Radio Shack has some nice small jumper wires with alligator leads on each end that might work nicely.
Old 01-19-15, 04:21 PM
  #47
LS400BOY
LS400BOY's Avatar
Im crazzy lol glade i asked,i dont lnow why i was thinking that i guess because i jumped the old fuel pump to see if it was working
Old 01-19-15, 04:36 PM
  #48
randal
randal's Avatar
Yeah, I am glad you asked too. I do not want to see sparks flying any more than you do. Just ask if not sure. So, you found the port connector ok? Its just a few inches beyond where the top radiator hose goes into the engine (thermostat). Gray lid on top.
Old 01-19-15, 04:56 PM
  #49
LS400BOY
LS400BOY's Avatar
I know now where its at since you showed the link to me,ill have to try tomarrow when its light out after work i hope
Old 01-19-15, 05:43 PM
  #50
randal
randal's Avatar
I cannot take credit for that link, thanks goes to Dicer. Remember, just jumper it momentarily each time while listening for the pump to run.
Old 01-20-15, 02:56 AM
  #51
dicer
dicer's Avatar
All you need to stick in those small little holes is a paper clip that you bend with your fingers and make a kind of a U shape out of, and stick it in the correct holes that Yamae showed in his picture.
Any wire with a clip on it will not fit. It has to be something very skinny like the average paper clip size.
And don't jump from the battery to anything UNLESS YOU REALLY KNOW WHAT YOUR DOING.
Oh and you get the codes out of that same port using that same paper clip using the CORRECT terminals or holes or what ever you wish to call them.
Old 01-20-15, 06:41 AM
  #52
Yamae
Yamae's Avatar
It's not quite OK to use a very skinny wire between FP and +B. There goes more than 10A when FP relay is off. You need to use a wire which endures against the peak current.
Recently I find some people who often mislead other people here in our forum.
Old 01-20-15, 10:32 AM
  #53
LS400BOY
LS400BOY's Avatar
I do got some small gauge wires i will use ill going to try this now,ill ley.you all know shortly
Old 01-20-15, 11:57 AM
  #54
dicer
dicer's Avatar
I was meaning a normal jumper cable won't work! A paper clip wire will handle 10A. If its me misleading let me know. Its hard to explain every little detail involved. And besides how big a wire can you get in those small blade connectors in that plug?
If I'm not being helpful, I'll stop posting then. I'll just ask questions when I need to. Need advice
Old 01-20-15, 12:10 PM
  #55
LS400BOY
LS400BOY's Avatar
Your very helpful to me
Old 01-20-15, 12:32 PM
  #56
LS400BOY
LS400BOY's Avatar
Ok well i tryed to paper clip and dont hear.anything,i think im connecting them right inside it,so of i dont hear nothing what does that lead to? I dont know if this can tell you something or not,after i turn the car over i will hear a noise from the back seems like the fuel pump noise? I know i supose to hear that noise when the key is in the on position before i crank it
Old 01-20-15, 12:59 PM
  #57
LS400BOY
LS400BOY's Avatar
I tryed a small gauge wire to and still nothing
Old 01-21-15, 01:31 AM
  #58
dicer
dicer's Avatar
Okay now go back to my long post in number 2 of this thread for what the problem maybe. Did you have the ignition on,,,,,key on....?
Old 01-21-15, 07:43 AM
  #59
LS400BOY
LS400BOY's Avatar
I guess i misread it i thought this was a way to jump with out it in the on position
Old 01-21-15, 12:29 PM
  #60
dicer
dicer's Avatar
The manual actually says to turn key on before jumping it. Maybe best just to follow the manual.
Did you ever get your spare wrecking yard parts, FP relay etc.? What about the harbor freight DMM? Its either free with a coupon or about $6. You can then check the relay coil for resistance. It will be handy for your electrical gremlins.
The way I understand it is the reason for jumping it is. For the fuel pump to run the ecu needs an RPM signal to know the engine is actually turning.
That is why initially when starting the engine the pump only runs momentarily, doing the jumper will run the pump with the engine off and not turning.
Quick Reply: HELP-car cutting off while driving
