92 ls400 interior gas smell
Old 01-15-15, 06:52 PM
wetcmonkey
wetcmonkey's Avatar
Default 92 ls400 interior gas smell
intermittent cel lean code. car runs fine. exhaust gaskets are blown.
just a history of my car before i start
i have a gas smell only when past half tank any suggestions?
i have a gastket for the fuel pump i may start there, are there anymore issues i should check for while im already working on the car? any experiences from you guys i can take to over look my own car?
ive replaced the gas cap and i tried to clean out the charcoal canister but i once in a while get a gas smell only above half tank.
Old 01-15-15, 08:00 PM
cobalt91
cobalt91's Avatar
I would check the vent lines ontop of the tank. Maybe one is cracked.
Old 01-17-15, 12:11 AM
LS400FAN
LS400FAN's Avatar
I've had this issue before, it was simply tightening the metal pipe that connects to the top of your gas tank. Working from inside your trunk, remove the trunk carpets and liners, follow the metal pipe from where you put the gas in to where it attaches to the tank. Tighten the pipe connection to the tank with a 10 mm socket wrench, I believe there are 3 or 4 screws, they have a way working loose sometimes, hopefully that will solve your problem.
Old 01-19-15, 09:39 PM
wetcmonkey
wetcmonkey's Avatar
Nice! Thanks for the info sorry for the late reply I'll be checking that out later tonight.
Old 06-19-24, 01:19 PM
TxCelsior
1st Gear
TxCelsior's Avatar
I just made an account to say thank you for this. I purchased a Toyota Celsior with no visible leaks or other issues, and after tearing apart my trunk (including the air purifier) and tightening those screws where the thinner metal pipe connects to the gas tank, the smell is gone. Thanks!
GoodRevs
12
01-14-24 01:43 PM
Bobzi
01-23-22 04:56 PM
budmantom
12-22-14 07:42 AM
jagjane
10-30-09 06:27 PM
The Ikon
SC- 1st Gen (1992-2000)
02-28-01 10:31 AM
Quick Reply: 92 ls400 interior gas smell
