P0340 after timing belt install
So, my son's 96' LS400 blew the front crank seal. So, I pulled it into my shop, and tore into it. I went ahead and did the timing belt again even though it was only 20k old. But, I figured with the amount of oil on it that it was a good idea to change it. Buttoned it all up, and its throwing a P0340 code. Camshaft sensor on bank 1. So, I replaced it with another one on a parts engine in the shop.
Symptoms:
1. with DS sensor plugged in it will stumble. (this occurred with both the original sensor and the replacement one)
2. With the DS Sensor unplugged it will run completely fine, but the Trac Off light blinks and the CEL stays on.
I am beginning to think its off a tooth at the crankshaft. I know the cams were perfectly aligned, but the new belt's Crankshaft mark was halfway between two teeth on the belt and not perfectly aligned on the belt itself.
Has anyone has this issue as well after a timing belt install by chance? I am just trying to justify tearing it down again. Its really throwing me off that it idles and runs perfect with the sensor unplugged. Thoughts?
Symptoms:
My thoughts you will not like. But I think you need to get back in there and check the belt alignment. The markings on the belt are just for initial alignment and thats it. After installing the belt initially with the markings, you should ALWAYS rotate the crankshaft several times and recheck for both engine mark to cam pulley alignment when the crank is at TDC. I do at least four revs or more because I do not want to be back in there. The only thing that matters is the engine bracket markings to pulley markings alignment. Disregard the belt markings after rotating.
Why would it run without the sensor? It could be in some limp mode which idles fine, maybe even revs but take it out for some performance and you will find all is not well. I think your initial timing positions are off.
Because I wasted time searching for a new thing (term) I never heard of, that is why I got a bit po'ed.
And also what I said too.
http://www.carbibles.com/automotiveabbreviations.html
This one says CKP for crank position sensor.
http://www.greatautohelp.com/automot...iations/c.html
It all depends on how the manufacture that writes the book abbreviates it.
Yes it does.
![](http://realmomkitchen.com/wp-content/uploads/2010/06/Over-the-top-M-M-Peanut-Butter-Cookie-top-300x300.jpg)
I am surprised there is no "DS" in your abbreviation catalog for "Driver's Side". Too bad, as it seems everyone else BUT you knew what I was talking about.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
