GS400 engine in LS400?
i'd wait for someone more qualified to reply but i'm not sure if it's that simple. there are a few differences between the two but i'm not sure if that's enough to make them not compatible
My 98 LS400 threw a main bearing at 250,000 miles. The camshaft is not damaged and I could replace the bearings but wondered if I should replace the engine and transmission with a lower mileage one. The local junkyard has a 98 GS400 which is what led to the question. I have seen a place in Dallas that sells imported engines that advertises the LS, GS and SC 400 engines as being the same. What years was the VVTI engine used? I've been looking for 98-00. Is this correct? Thanks for everyone's help.
daihap133
07-03-11 07:15 PM
guest
04-06-06 08:28 PM
