Major Electrical PROBLEM
Old 02-06-15, 11:59 AM
timmy0tool
timmy0tool's Avatar
all battery terminals are the same size. you should be able to find them easily as they are plenty of generic ones out there that should work.
so no lights at all, not even the dome light? parking lights?
Old 02-06-15, 01:48 PM
Mattreed7
Mattreed7's Avatar
absolutely nothing. no headlights, no automatic locks, no power windows, no power seats, no click when key is turned. zilch.
Old 02-06-15, 05:06 PM
randal
randal's Avatar
Thats actually a good thing. Should be easy to find. It is most likely a cable, ground, or fuse, provided the battery is really good.
Old 02-06-15, 09:07 PM
sam12345
sam12345's Avatar
Fusible link fuses is my guess
Old 02-09-15, 09:14 AM
Mattreed7
Mattreed7's Avatar
Anyone think it could be the alternator?
Old 02-09-15, 04:32 PM
Yamae
Yamae's Avatar
Are you sure? What about the galvanic corrosion?
I have seen many owners having problems without knowing the fact. Don't select terminals that use dissimilar metals with the battery post.
Old 02-09-15, 07:14 PM
timmy0tool
timmy0tool's Avatar
good thought, but it would be hard to find a terminal clamp of the same metal since i don't think they specify it on the packaging. i would just get the regular silver metallic clamps.
i see terminals that are gold coated. would that be a bad idea?
Old 02-09-15, 08:40 PM
Yamae
Yamae's Avatar
Sorry to say but it is a bad idea which may cause 0.7V of the voltage difference and causes galvanic corrosion shortly. It would be best if the post was also the Gold or Rhodium plated on silver-plated copper. See below and you will see how dangerous it is to use the one you showed.
http://www.engineersedge.com/galvanic_capatability.htm
Some people here are kind enough trying to help other people but I find them misleading others sometimes without knowing the deep fact. May be I am one of them too.
Old 02-10-15, 02:59 AM
dicer
dicer's Avatar
We all thank you Yamae. And please if any of us say the wrong thing I'm sure we all would want you to correct us. Your one of the important people that comes here and you have offered some very helpful information.
I reread the replies and mention of dissimilar metals from battery post. Its going to happen some place. What I mean is if it is a lead clamp the wire in it will be copper. And as far as I know my factory terminal clamps are made from steel, though they maybe coated with something. I guess with this I am asking a question and not anything else with it.
hankster2
RX - 1st Gen (1999-2003)
12
04-09-18 04:11 PM
igorxx
01-18-14 04:56 PM
lalexusgs
01-24-06 01:29 PM
XSTeknique
Performance & Maintenance
11-15-04 03:27 PM
SilverLexo
07-19-04 08:26 AM
Quick Reply: Major Electrical PROBLEM
