Shortened spindles
Shortened spindles
Ok who here has had their spindles shortened ( by cutting and re welding)? I'm looking at doing mine ASAP, I'd just like a little more info as far as the route you went. I'm effectively going to create drop spindles with 30mm RCA's. So, I'm assuming I'd have to remove 30mm of material from the spindles as well. Has anyone done 30mm RCA's and a 40mm reduction?
might not get a lot of info here since the majority do not do demon camber on their cars. you should check VIP forums for this kind of info.
in my mind, i would not remove too much as to ruin wheel clearance but of course you would have to run low offset wheels (or spacers) to clear.
here is a sample of a modded LS knuckle:
it's possible but you need to do it in a couple of steps and then brace the hell out of it. As has been said, there ae a couple of places that do it.
Besides going with an Onikyan setup, the main reason to do it would be to regain the UCA angles at extreme static drops.
Thanks for the feedback fellas. My purpose for the modification is to eliminate bump steer and also prevent the control arm from kissing the shock tower. I am not a fan of camber at all, and all my suspension mods will reflect that. I'm building a daily driven/show car, (with a family of five) I guess I'll have to bite the bullet and buy aftermarket. Spindles breaking in half is not an option for me while doing 70 on the freeway. I'm not willing to gamble with someone attempting to weld cast steel without proof of reliability/durability.
ka0bit0
Wheels and Tires Classifieds
08-23-16 02:31 PM
tientony
SC- 1st Gen (1992-2000)
59
02-26-12 03:08 PM
