automatic transmission slipping
Hi! The automation transmission of my 1991 LS400 is slipping. The fluid level is good. It started about a few weeks ago and is now getting bad. Wonder if anyone have the same experience.
Have you tried adjusting the trans cable by the throttle?
https://www.clublexus.com/forums/ls4...or-softer.html
This seems to have helped me on my 91.
when was the last time the fluid was changed? around here we do NOT recommend a flush but a simple drain and fill between 3-4 oil changes. a drain and fill necessitates 2 quarts of ATF. only use OEM toyota type-IV ATF!
also make sure you check the level using the 'hot' side of the dipstick, on a level surface of course. hot means you drove the car around for a least 20-30 mins.
msdelexus
14
05-31-10 02:04 AM
