91 Ls400 starting issues
Hello clublexus. OK so I'll start out by saying I've been searching for a few hours now and I've come up with nothing. OK so on the the problem,
My starter originally went out on my 91 ls400, replaced that, deleted egr, put it back together wouldn't start, ac compressor had seized and serpentine belt snapped, bypassed that, cranked but wouldn't fire, wiggled the efi relay and it fired up, then died, vacuum leak, fixed than, ran like a dream, test drove and came back.
Now on to the problem at hand now, when I got back from my test drive the motor was smoking, leaking injector oring, but the car ran with no issues. Pulled out the injectors, replaced all the orings, and now when I go to start it, it cranks fires and then dies, regardless if I have my foot on the pedal or not, I hear the fuel pump priming after every start, and the car will stay running if I spray starting fluid in the intake. It has me super confused because it ran before I replaced the orings. No check engine light either. I tried jumping B+ and Fp terminals and didn't hear the fuel running through the rail or return line. Pulled out fuel pump relay, tried to start wouldn't start, put it back in and it fired. Opened ecu and didn't see any leakage from the caps but I'm not ruling those out just yet. Any help would be appreciated. Or if someone could point me to a thread that I might have missed would be greatly appreciated.
I know the CEL works because it illuminates when i turn the key on but then goes off as it should
That's how my 92 sc400 was when it didn't have a coil pack, but the connector I'm talking about was the two wire one on the bottom of the passenger side coil, it wasn't even connected, and i read somewhere that if the ecu senses something like a coil not plugged in, it wont run the fuel pump so it wont flood the motor.
porshapowe
02-24-07 08:36 PM
