93 LS400 Engine Temp Indicator at 40%
Got my LS400 a few months ago, fantastic car and drives like a dream. One question on the engine temperature indicator maxes out at around 40%, which is right at the indicator mark below 50%. It never moves up beyond that no matter how much I drive. If I drive on the freeway at 60-70Mph, the temperature needle will actually drop down to around 30-35% and when I slow down or stop, the indicator will go back up to 40%.
Does your 90-94LS do the same thing, or should I change the thermostat? I have already changed the Engine Coolant Temp Sensor and it made absolutely no difference.
Thanks in advance for your response!
Sounds normal to me.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
It is not normal, your thermostat is stuck open, i was having exactly the same issue 2 weeks back...
Check your thermostat and replace it if required
My problem solved by replacing the damaged thermostat!
+ Don't buy an aftermarket thermostat !
Normal temp reading would be in the middle which is = 86 Celsius
Yes, when driving in the highway, it will drop down to 30% and will move slowly up to the 40% mark if I slow down or stop. Very strange as I never seen this on any of my other cars. Thanks for your input, I am going to bring it to my mechanic and have a more detail look.
96UCF20
13
06-12-16 06:07 PM
Jlacck
32
02-25-15 06:32 PM
chrisngo
10-19-08 04:06 PM
