tt supra calipers
Old 03-20-15, 06:15 PM
skihawaii
skihawaii's Avatar
Default tt supra calipers
Would I gain front clearance if I switch to tt calipers from 99 ls calipers?
If so anyone know how much?
Would there be a gain or loss in braking power?
if loss, noticable?
Old 03-22-15, 11:08 PM
YoshiMan
YoshiMan's Avatar
I don't think there is going to be much information on this, as LS400s generally have the best brakes available on any Toyota model (not including the newer Tundras) and people tend not to screw with them
Old 03-23-15, 10:14 AM
RA40
Super Moderator
RA40's Avatar
We have a thread somewhere here discussing the dimensions. It is a minimal difference between them my memory recalls. Certainly not enough if you need 10-15 mm because the wheels are not high disk. Talking maybe 3-6 mm at most for that. PD (Puredrifter)had probably posted it regarding the swap on the 1-LS using either the Supra or 2-LS caliper differences.
Old 03-23-15, 07:11 PM
timmy0tool
timmy0tool's Avatar
actually i heard that YES you will gain more clearance when going supra TT calipers bc they are smaller in cross sectional dimension. the exact number escapes me but i can guesstimate around only 3-5mm of clearance gained. The LS caliper is slightly lighter though.
i would just get wheels that fit better, or spacers to clear your calipers.
Old 03-27-15, 09:26 AM
akitomk3
akitomk3's Avatar
Unless you already have the wheels, I wouldn't change the ls brakes over to the supra TTs to gain a few mms.
Old 03-30-15, 12:58 AM
skihawaii
skihawaii's Avatar
It's for a street rod.
so I might just get different wheels.
supraguy2
03-06-12 11:06 AM
Lextreme
Suspension and Brakes
20
04-28-10 02:37 PM
parnzen
04-21-09 10:14 PM
mrshabo
SC- 1st Gen (1992-2000)
31
05-12-04 10:49 PM
Quick Reply: tt supra calipers
