Ls400- 1995 ECU problem
I have ls 400 model 1995. The ecu board burned it can't be repair. And new ecu is too expensive. Ecu part no 89661-50270. Any one can help ?
Welcome to Club Lexus.
Is this the original country the car was meant for or had it been imported? Is your a left or right hand drive? A '96 ECU should also be compatible. Is there a salvage yard that has parts for these cars if this is a possibility then you can inquire if they have an ECU.
Asa reference we have this thread of ECU part #'s for the US and some other countries listed:
https://www.clublexus.com/forums/ls4...ml#post8762081
It's left hand. Earlier I installed ecu for 96 it give smoke and so rich. I repaired the original one and it was ok. After 7 month board burned now I installed the 96 and it same give rich smoke
Ls 400. Model 1995 couldn't fined exact number of Eco. The Eco burned and can't be repair. I found other no of Eco I installed but it give rich smoke. Any suggestion ?
