Blown factory amp. Can I replace with a new head unit?
I am picking a 97 up this weekend. It has a blown factory amp so no sound from speakers. I am wondering if I can just install a new head unit (aftermarket) to address the issue. I listen to music mainly off my phone anyway so I would get one with an AUX port. Or will I need to replace the factory amp before I install a new head unit ?
I believe its Pioneer. You turn the audio unit on, you'll hear a small "pop" from the speakers. The speakers produce no sound. I haven't personally seen it yet, this is what the seller has told me. I have an IS350 as well and when the factory amp blew it did the exact same thing.
I have a 90 that had an aftermarket head unit install, it had a special wire harness adapter and used all the existing speakers in the car. It is a simple install or remove, I removed it.
Are you certain that the amp is defective? Lack of sound is more often caused by a head unit issue or a problem with a phone system wire in the trunk grounding and putting the audio system into permanent mute mode.
I'm not certain. I am just assuming going off my own experiences. Does the factory amp power the sub only or the speakers as well?
How can u check this or unmute I have tried everything else
Does you LS400 have a Lexus brand phone system? I don't see the model year in your profile or in this thread but the phone ECU for the 95-00 LS400 is under the false floor on the right side of the trunk. If the phone ECU is there, then unplug all the connectors from it and plug the two large connectors together. Secure all the connectors so that they don't contact the floor and possibly get wet. On the 95-00, the two large connectors can be plugged through a plastic bracket attached to the bottom of the tool kit receptacle to keep them up and out of the way.
If the audio system still is muted, check for corrosion in the phone ECU connectors in the trunk. I remember one case on this forum where the wires in the connectors were so corroded that they were falling apart.
A shorted out phone ECU is just one of the issues that can cause the audio system to be muted. The Nakamichi in my 2000 LS400 lost it's right channel due to a problem in the head unit.
CVBigRig
03-16-14 05:43 PM
ArmyofOne
12
11-03-04 12:09 AM
DJ SprinklesNJO
04-02-02 09:34 AM
arcwelder
09-25-01 09:07 AM
