1998 LS400 Turn Signal Lights Ejecting Themselves
Old 05-31-15, 05:12 PM
Dart562
Dart562's Avatar
Default 1998 LS400 Turn Signal Lights Ejecting Themselves
Surprisingly I haven't found anything about this on any forums but this is the second time it's happened to me. While making a high speed run my turn signals will fall straight through and onto the floor and you do not notice it happening till you try using them again and the flash is really quick. The first time it was only my passenger turn signal but the most recent Time took both sides out. Does anyone have any solutions to this? Could come up with something myself but I'd like to get some ideas if possible. 😅😜😇🔧🔨
Old 05-31-15, 06:23 PM
sha4000
sha4000's Avatar
Do you mean the bulb comes out of the housing or the housing ejects from the car?
Old 05-31-15, 06:25 PM
Dart562
Dart562's Avatar
Default Reply
The whole housing light bulb and all
Old 05-31-15, 06:29 PM
sha4000
sha4000's Avatar
Ok, this has happened to my passenger side light several times. I'm betting that the housings don't snap into the headlight all the way so they are sticking out a little. When the air gets in between the bumper and the light the pressure pulls the turn signal housing right off.
Old 05-31-15, 06:30 PM
rudyH
rudyH's Avatar
How about a little detail.
Old 05-31-15, 06:33 PM
Dart562
Dart562's Avatar
Default Reply
Going full throttle down a long empty road get to atleast 140 and than when get out to see why my blinkers are going crazy I find that both turn signal housings are missing... Don't know when they fell out or anything doesn't make a noise at all when it happens.
Old 05-31-15, 06:34 PM
Dart562
Dart562's Avatar
I believe it is falling straight through because the first time it happened I did notice that there was a whole where it looked like it ripped under the splash guard but I'm not positive
Old 05-31-15, 06:37 PM
sha4000
sha4000's Avatar
It can't fall straight through where the splash guard is placed. I just told you that this happened to me a couple of times and why it is happening. The housings are not snapped into the headlights properly.
Old 05-31-15, 06:47 PM
rudyH
rudyH's Avatar
That's what I would have suspected. Even if someone had screwed up somehow and enlarged the holes you wouldn't be able to snap them in in the first place. Or the tab surfaces on the light housing are missing but again, you would notice they aren't snapping in.
Old 05-31-15, 07:21 PM
UNCNOR
UNCNOR's Avatar
Is it April !st???????????
Old 06-01-15, 01:09 PM
TMaxxTim
TMaxxTim's Avatar
Yeah, after I had some body work done on my LS, I had one fly out on the interstate...granted I was going about 90 when it happened. The body-shop put a new one in and made sure it was much more snug in there that time. I haven't had a problem since.
I'd say just fool around with it in the housing until you feel that it really is "secure" in there.
Old 06-01-15, 01:17 PM
timmy0tool
timmy0tool's Avatar
is someone messing withis us haha?
there should be a single screw to hold the housing in place. even if the housing were to come loose, the bulb holder should hold the housing to the car and just dangle there. if the bulb holder AND the housing ejects, you are doing some SERIOUS offroading!
Old 06-01-15, 01:21 PM
timmy0tool
timmy0tool's Avatar
https://www.clublexus.com/forums/ls4...placement.html
or
Old 06-01-15, 01:37 PM
sha4000
sha4000's Avatar
Not true. Mines has been ripped out with the bulb still in the housing on the interstate. For some reason on early 98s the passenger side housing does not always fit correctly. I've used an aftermaket Amazon housing and an OEM housing with the same results. When the bumper does not fit snug under the lights air gets in there and at high speed the pressure pulls it right out of the car.
Old 06-02-15, 12:01 PM
dicer
dicer's Avatar
And so how does it fall onto the FLOOR??????????????????? The floor is in the inside of the car. And the ROAD or pavement is on the outside of the car, especially when you are driving it and the lights fall out.
Quick Reply: 1998 LS400 Turn Signal Lights Ejecting Themselves
