Toyota Celsior Error Messages Translated
Hello all,
I have a JDM 1999 Toyota Celsior with an error code I cannot decipher.
The car is running just fine and only comes on when I get in the car or turn off the engine so I am puzzled to what it may be?
I have tried to use google translate to draw the Kanji but none of the translations make sense?
I have attached the error message.
It says, "Moon roof is open".
Those characters are called Katakana not Kanji, I must add.
Katakata is usually used for words from other languages.
ムーン = Moon, ルーフ= Roof, オープン = Open
Sorry that I don't accept any personal questions to my box any more. There come too many questions next to next and I have no idea to answer those separately using my limited English or Spanish.
The message is nothing to do with your modification of the suspension. Simply it is caused by the open moon roof or the sensor. So what you need to do is just to check those.
Re:
Thank you very much Sir!
I opened and closed the moon roof and it appears to close all the way.
I also checked to make sure nothing was on the tracks to cause it to stay open and the error message remains.
I will research replacing the sensor moon roof sensor.
QUOTE=Yamae;9069761]It says, "Moon roof is open".
The message is nothing to do with your modification of the suspension. Simply it is caused by the open moon roof or the sensor. So what you need to do is just to check those.[/QUOTE]
