Aisin water pump gasket part #, help.
Old 06-15-15, 07:52 AM
GSa
GSa's Avatar
Default Aisin water pump gasket part #, help.
Hi, I bought a timing belt/water pump kit off ebay for my 99 LS400. There is a rectangular gasket that Aisin no longer includes with their water pump that I need. I talked to the company that I bought the kit from they gave me the part number for the same gasket for a Toyota Tundra 4.7l, which is not right and I talked to 3 lexus parts guys and my mechanic and somehow none of them could figure this out.
I will include a picture of where this gasket fits to on the water pump. I figure you guys are the real experts.
Attached Thumbnails Aisin water pump gasket part #, help.-waterpumpgasket.jpg
Old 06-15-15, 07:55 AM
sha4000
sha4000's Avatar
There's no gasket. Your supposed to use FIPG ( fixed in place gasket ). Just go to any parts store and get the Permatex FIPG. I believe it's the one in the grey tube.
Old 06-15-15, 09:00 AM
aptoslexus
aptoslexus's Avatar
delete. Wrong part.
Old 06-15-15, 02:22 PM
mikaelse
mikaelse's Avatar
Default I made a gasket from sheet gasket material
Original gasket was black silicone? . No other gasket . Feels better with some gasket material there to give some Surface pressure to whole surface. I bought general gasket material sheet 0.4 mm (1/64") thick. Cut out a gasket with a scalpell and used Permatex on both sides. Sealed well.
Old 06-15-15, 05:08 PM
paulo57509
paulo57509's Avatar
If you want to use a gasket, you need Fel-Pro P/N 35941.
Old 06-15-15, 05:57 PM
aptoslexus
aptoslexus's Avatar
Nope. Doesn't fit. Only way I've seen to get a gasket is to order the Beck Arnley water pump kit that includes the gasket. There's a Fel-Pro 35552 that fits 90-96, but apparently not the later models.
Old 06-16-15, 07:45 AM
Banshee365
Banshee365's Avatar
You must not work on Lexus/Toyota's much. They use FIPG almost everywhere. I use the stuff from the dealer it's really good stuff. Your oil pan, transmission pan, rear diff and the water pump port are a few of the things assembled with FIPG. The thermostat housing has a groove machined in it to run the thin bead of FIPG in to seal to the water pump. I've done this many many times and never had a leak, especially with the OEM FIPG from the dealer.
Old 06-16-15, 01:40 PM
GSa
GSa's Avatar
Ok, well thanks a lot you guys are great help. Amazing how no lexus parts guys could figure that out, on top of the company that sold me the part. This is what my mechanic said he would do anyhow if I couldn't find the (non-existent) part. Thanks again.
Old 06-16-15, 07:03 PM
timmy0tool
timmy0tool's Avatar
yep FIPG is what you need to use. look at your old part, FIPG is there.
Old 06-17-15, 06:47 PM
paulo57509
paulo57509's Avatar
My mistake. Fel-Pro P/N 35941 is for the bypass.
peterls
13
07-31-19 08:27 AM
400ls
05-08-13 08:09 AM
deanbrown
07-07-11 09:22 AM
AZ Mike
01-30-09 12:23 AM
CPALex
09-10-05 09:44 PM
Quick Reply: Aisin water pump gasket part #, help.
