Factory GPS has got to go!
Old 07-02-15, 07:46 AM
tsxnbp
tsxnbp's Avatar
I am glad someone is actually going to finish what I always planend to complete!
I know the wood piece can be removed from the non-NAVI vent as I have seen it done by someone in Japan...which means it can also be removed from your original NAVI vent to be swapped out.
Here are some pics to prove it....good luck with the conversion!
Old 07-02-15, 08:40 AM
Hiroshi12
Hiroshi12's Avatar
Thanks for the photos (tatami mat ^^^). Yup, the "wood" pieces are attached to the vent trim piece with a few small screws so it should be easy enough to do the swap. In fact, I was hoping to just leave mine in place and do the swap with the vent still mounted. Unfortunately, that may not be an option since there are screws behind the vent which need to be removed (see attached) in order to take out the factory HU. Just hoping that the 17 year-old plastic doesn't snap in the process
Old 07-03-15, 11:42 AM
Hiroshi12
Hiroshi12's Avatar
All of this is going in this weekend. No problem, right?
Old 07-14-15, 08:02 AM
Hiroshi12
Hiroshi12's Avatar
No progress yet. My OCD led me down a different path as I decided to clean out and renovate my garage first. Finished the clean-up last week and did a garage sale this past Saturday. Too much other stuff going on too, but I hope to tackle this install soon.
Old 07-20-15, 09:12 PM
GH5T
GH5T's Avatar
Any progress on this yet?????
Old 08-09-15, 08:41 AM
Hiroshi12
Hiroshi12's Avatar
So this weekend I FINALLY got off my butt and began the install of the new HU. Before I continue, I want to thank previous CL members for these threads which helped me greatly:
https://www.clublexus.com/forums/ls-...b-working.html
https://www.clublexus.com/forums/ls-...unit-swap.html
https://www.clublexus.com/forums/ls-...-98-ls400.html
Old 08-09-15, 08:47 AM
Hiroshi12
Hiroshi12's Avatar
The first step is pretty obvious and has been covered elsewhere but I'll include it anyway. To remove the a/c vent and trim piece, locate the small tabs on either side (they are inside the vent) and push them outwards with a small screwdriver while prying on the sides of the housing with something flat. I used a new plastic putty knife. Once it's out, disconnect the electric connector for the hazards.
Old 08-09-15, 09:00 AM
Hiroshi12
Hiroshi12's Avatar
If you're swapping a non-navi factory unit for a new HU these next few steps would not apply to you since your trim piece and climate controls are already there. In my case - I am going from factory navi to after market HU so I had to mod the wood trim (my original is too "short") and incorporate a non-navi climate control module into the build. Anyway, I had to further disassemble the vent in order to continue.
Unfortunately the donor piece was thrashed with most of the brittle little plastic tabs broken off or this would have been much easier. I had to remove the trim from the donor piece (thanks again tsxnbp) and transfer it to the one going back in the car. Very tedious work here
Those six holes you see on each piece are where some plastic "rivets" held them on (Lexus over-engineering!) in addition to two screws. Separating them with my razor blade technique nearly made me stop breathing with every wack of the hammer, but it was a success...no shattered plastic.
Attached Thumbnails Factory GPS has got to go!-2015-08-08-14.08.24.jpg   Factory GPS has got to go!-2015-08-08-14.23.33.jpg   Factory GPS has got to go!-2015-08-08-14.15.22.jpg
Old 08-09-15, 10:25 AM
Hiroshi12
Hiroshi12's Avatar
Once I connected the new wood trim it was time to reassemble the entire vent piece. This was also not easy since 4 moving parts had to be lined up just right while snapping the tabs together. After a few tries...job done!
Attached Thumbnails Factory GPS has got to go!-2015-08-08-14.34.05.jpg   Factory GPS has got to go!-2015-08-08-14.50.05.jpg
Old 08-09-15, 10:28 AM
Hiroshi12
Hiroshi12's Avatar
The next little job to do was prying my second-hand climate control box apart so I could replace the factory green back lighting with brighter LEDs. A few screws and plastic tabs again and I was in. There are 10 little lights total, easy swap.
Attached Thumbnails Factory GPS has got to go!-2015-08-08-14.59.43.jpg   Factory GPS has got to go!-2015-08-08-15.00.09.jpg
Old 08-09-15, 10:36 AM
Hiroshi12
Hiroshi12's Avatar
NOW, I can finally begin the removal/install process. As with any auto job involving messing with the electrics I highly recommend disconnecting the battery. Next thing to do is to get the gear selector pushed all the way back, unscrew the shift **** and CAREFULLY pry out the center console wood grain plastic. Believe it or not - there are no screws or tabs in this step...just some even pressure does the job. There will be a few electrical connectors here to disconnect as well.
Attached Thumbnails Factory GPS has got to go!-2015-08-08-15.22.29.jpg   Factory GPS has got to go!-2015-08-08-15.34.43.jpg   Factory GPS has got to go!-2015-08-08-15.37.23.jpg
Old 08-09-15, 10:46 AM
Hiroshi12
Hiroshi12's Avatar
There are 4 10mm bolts holding the factory navi/climate control/audio unit in. The top two were exposed when the vent was removed and now with the center trim gone you can access the bottom two. Remove the four bolts, unplug ALOT of connectors, and gently pry the old lump out. Check out this behemoth - that's a whole lot of 90's tech folks!
Attached Thumbnails Factory GPS has got to go!-2015-08-08-15.48.00.jpg   Factory GPS has got to go!-2015-08-08-15.49.38.jpg   Factory GPS has got to go!-2015-08-08-15.55.10.jpg   Factory GPS has got to go!-2015-08-08-15.59.25.jpg   Factory GPS has got to go!-2015-08-08-16.00.23.jpg
Old 08-09-15, 10:53 AM
Hiroshi12
Hiroshi12's Avatar
I'm gonna need to reuse the Lexus factory radio brackets for the new install so I disassemble the entire package which was quite easy since just four or five screws per side holds it all together. I didn't take any pictures of that process but the shots below show the re-installation of the brackets on the new HU. The first bracket you see is the one provided by beatsonic. That goes on first, then the OEM bracket.
Attached Thumbnails Factory GPS has got to go!-2015-08-08-17.41.03.jpg   Factory GPS has got to go!-2015-08-08-17.42.33.jpg
Old 08-09-15, 10:56 AM
Hiroshi12
Hiroshi12's Avatar
What I am really doing here is just mocking-up the whole thing to make sure everything fits before I even attempt any wiring. Now that the brackets are in place it's time to fit the beatsonic faceplate and the "new" climate control module. Looks good on the bench, right?
Attached Thumbnails Factory GPS has got to go!-2015-08-08-17.42.58.jpg   Factory GPS has got to go!-2015-08-08-17.46.17.jpg
Old 08-09-15, 11:04 AM
Hiroshi12
Hiroshi12's Avatar
Next, with the vent test-fitted I do a temp. install into the car without wiring up anything except the climate control unit because it would be a MAJOR show-stopper if that sucker didn't work. Test went ok - all controls appear to be working normally. Only problem is that half of those little LEDs are not illuminating...maybe I twisted them in the wrong way during the install?
Figuring that one out will be the first job today and then...the actual HU wiring begins. I'll also be doing a hands-free mic and a rear view camera and I plan on taking my time every step of the way so I doubt I'll finish this today. Plus I gotta get up at 0300 to fly cross-country on a business trip tomorrow, so uh.........
Attached Thumbnails Factory GPS has got to go!-2015-08-08-17.46.50.jpg   Factory GPS has got to go!-2015-08-08-18.05.32.jpg
Quick Reply: Factory GPS has got to go!
