97 LS400 wheel fitment
I have a 97 LS400 I picked up some wheels for very cheap from my friend and not sure if they will fit. They are PCD 5x115/120 offset is 35mm and the hub is 74.1. I can get some adapter's that are 1.25" thick. To get the bolt pattern right. I believe the factory off set is 45mm. Anyone know if this will fit ok? Thanks
I thought they was kinda thick adapters, I'll try looking for some thiner ones. Why would I need hub rings? My finders are already rolled a bit from my other set of wheels, not sure of the with of them but they was also 20. The back wheels was wider. Off the top of my head I believe the back tires was 275/30/20 and the front are 245/35/20. That set up came with the car when I bought it. Oh and it's lowered about an inch.
There are many 25mm adapters for various bolt patterns. There are custom adapters and one of the threads here the owner used 15mm. Given the 35mm offset and if your car is lowered, fender mods are required. I'm not so positive on 15mm adapters with so little stud seating metal on them. 20-25mm would be more secure IMO.
AtlasLS400
10-14-14 07:21 PM
sunblinds
04-13-06 02:55 AM
