Low idle, shift early @ 5000rpm at WOT
I am not sure how well this will help in your case but there's multiple things that could be off, Ecu causing tranny to shift earlier, tachometer is old and reading wrong, tranny fluids. Those are the problems listed above; however, I ha a similar problem in a 92 Ford F-150, and it turned out to be a speed sensor on the transmission itself, not sure if these LS4's have them as I haven't really checked on my car yet, but that seems to be a common problem to my knowledge.
Its the stupid gauge that is not showing you the correct rpm. If it is drug down and kills the engine in gear you may have a transmission problem.
Or like in the above post as well.
And now you mention misfire? In your original post there is no mention of that!!!!!!
This was posted 2 days after i originally posted, trying to say its graduating into something more, etc.
UPDATE: Car still showing low idling on the tach but it's not idling that low. Still shifts at 4500rpm area at 80mph, getting the same gas mileage as always.
Not sure whats wrong but it isn't getting worse and just seems to be the tach is reading the wrong rpm signal from something.
Not worth the money to investigate and fix at this point.
The tach on my car is doing the same thing. Car idles great, runs great and sounds great. If I rev it to 800 in park it sounds like it's racing and when I put it in drive the car lunges. I picked up a used cluster so we will see. I have a IR device hat will read rpm's so I'll use that to check first. I have what feels like a miss only in the 55-60 mph range but my tach says 1k rpm and I know that's not right. Also my wife said she fills it up on Sunday but the needle stayed at half so the that kind of confirms the bad cluster. You've done a lot, and some of the things I have yet to do. After I check the TPS I think I'll give in and take it to a shop.
Does yours shift around 4500 when you max out first gear in D ?
grindin8o8
Performance & Maintenance
03-08-10 06:25 PM
qha_vn
11-17-08 12:23 PM
Big Daddy
06-13-08 09:54 PM
