95 Lexus LS400 Bluetooth Add-on w/Pics
The main goal I need is to keep all original with limited mod but high quality stereo sound wireless through smartphone.
Here is my solution:
Smartphone or devices with bluetooth aptX profile support or at least A2DP
Bluetooth receiver with aptX support and HiFi DAC chip ($30 to $200, no huge different as I test)
First thing first is add on a aux input where I choice mod cassette as I never use it before.
Searching the forums, I got this apart from the center console
I need a power surply and a switch through cigar lighter receptacle
Disassembly a smartphone charger as bluetooth receiver power supply
Bluetooth receiver will hide behind panel
Option: you may not need a power switch if you wanna keep BT receiver ON all the time and that will keep mod more easy with constant power supper when ignition on.
Note: Aux input ground will connect with the metal frame behind panel.
You need mod a cassette adapter as it will running endless
I need slip sheets inside to eliminate friction noise
See the brown sheet
Seems nothing happened, now you can enjoy your Nakamichi high quality sound wirelessly.
See the brown sheet
Sherl (03-01-19)
