UCF10 offsets
Old 08-13-15, 04:33 PM
dief
dief's Avatar
Default UCF10 offsets
new to the ucf10. I've been searching on here a lot and have learned a lot. I'm coming from the vw/audi scene so i'm trying to learn the most I can here.
From what I understand so far, there is a difference in what offsets will work on ucf10's vs. ucf20's, with the ucf20's allowing for lower offsets in the rear. I've been trying to find pictures of ucf10's lowered on a 19x9.5 square setup and I'm not having much luck. I want to know what works better, an offset of around +40 or more like +20 in order to be tucking tire with some camber and rolled fenders.
Any info is appreciated. Thanks
Old 08-13-15, 06:47 PM
sha4000
sha4000's Avatar
Just go through this thread and take your time.
https://www.clublexus.com/forums/ls-...eel-setup.html
Old 08-13-15, 07:42 PM
dief
dief's Avatar
Yeah, I've been through that thread. I couldn't find much solid info for the ucf10's. Looks like people are running 19x9.5 with +20 and below offsets on ufc20's. But if the fender dimensions are different, then those numbers don't help me much.
Old 08-13-15, 08:02 PM
Auxive
Auxive's Avatar
Get measurements of your current wheels, the distance to brakes, distance to suspension, and distance to fender. Then enter it into a calculator ( http://www.1010tires.com/Tools/Wheel-Offset-Calculator ) and calculate it. It's not too hard. If you get correct measurements, then the calculator should give exact measurements of how the setups would look.
Old 08-13-15, 11:05 PM
RA40
Super Moderator
RA40's Avatar
This is an old fitment for basically stock fenders or with some slight mods like shaving-rolling as applicable. This isn't a flush fitment, this will give a ball park range.
13FSPORT
GS F (2016-present)
04-10-17 03:35 PM
Advil4u
09-29-13 12:25 AM
seivonecsu
03-23-13 07:59 PM
7akata
Wheels, Tires & Brakes Forum
03-11-13 07:13 AM
Micdizo
04-02-12 10:11 PM
Quick Reply: UCF10 offsets
