91 LS400 car starts after 2 seconds dies
I got a 91 LS400, car will start but dies after 2 seconds, it will fire right back up and then dies. I can keep it running by consistently blipping the throttle. If I hold it steady state it will die.
Changed the ECU capacitors, cleaned the IAC valve.
Someone mentioned jumping the fuel pump resistor but I couldn't find it.
Any ideas?
thanks
Any ideas?
thanks
It sounds like an inhibit mode to me. Hope the link below may help you to find the root cause.
https://www.clublexus.com/forums/ls-...ml#post9073825
So either its both knock sensors, the connections, the wires, or ecu circuits. Who changed the caps? Did they use ESD precautions? Solder joints were made correctly?
Spark goes to max retard with those codes.
I did the caps. Yes to ESD and solder.
But wouldn't you also get knock sensor issues if there was a problem with the EFI?
Would retarded timing make it run, almost die, run, almost die etc...
Are the codes a symptom or cause of problem?
Sometimes it will run, almost die, then run, almost die, then run, etc... it can go for 10 cycles of this. But when you turn the key over it will again start right back up and sound normal for 2 seconds and either die or cycle.
Thanks for the responses.
I have seen codes set that have nothing to do with the problem on some cars.
I would be looking at crank position sensor. Its part of what Yamae's post is about.
If you know what esd is then you might know how to use a scope, you could trace the various signals.
And normal diagnostic stuff, check fuel pressure etc.
mjkwee
15
06-02-20 05:47 PM
mercedes84
08-23-15 05:55 PM
yahdie1
08-25-08 03:04 AM
