so I think I'm going to need a power steering pump soon.
Old 08-31-15, 06:42 AM
rick1987
rick1987's Avatar
Default so I think I'm going to need a power steering pump soon.
When I start it in the morning I can bear the pump whining, sounds kinda like a ford pump.
So I've been looking on eBay for a oem used pump that I can rebuild. But I don't see much.
Any recommendations for a rebuilt one?
Car is a 2000.
LSnewb (06-02-22)
Old 08-31-15, 08:43 AM
Legender
Legender's Avatar
I put a reman on from O'Reillys and have not had any trouble on my 1998...that was about 2k miles ago.
I'd look close and make sure the pump is not leaking onto the alternator or you'll be replacing both of those items. Make sure you use ATF in the power steering pump as that is what it calls for... not power steering fluid...just a friendly reminder.
Old 08-31-15, 09:26 AM
rick1987
rick1987's Avatar
Yes, the previous owner put power steering fluid, I had to flush it when I got it.
Old 08-31-15, 01:57 PM
k7q
k7q's Avatar
Aliga on here should have a used OEM pump.
Old 08-31-15, 08:59 PM
qewani1
qewani1's Avatar
mine also is leaking, does rebuild works? how long it will last with rebuild?
Old 08-31-15, 11:43 PM
YoshiMan
YoshiMan's Avatar
When I bought my 95 a few years back, it had a faulty pump and i replaced it with a rebuilt one at NAPA. Pump worked great with no leaks for the few years i had it, up till I traded it in on my LS430.
Also, i had to put a rebuilt pump from Orielys in my 4Runner back in 2006. Been holding up great ever since. I think that P/S pumps are one of the few things that actually are rebuilt properly at local autoparts stores
Old 09-06-15, 07:05 PM
UNCJD
UNCJD's Avatar
Car is a 2000.
I just got one from Autozone. Havent driven it much yet, though. I'm currently working through the car's other issues.
Another thing, in case you didn't know...the remans don't come with ACVs. You'll need to keep your old one or bypass it. Replacement ACVs are $108 at Advance Auto.
ejthomp
12-31-18 10:34 AM
worldforgo
02-04-12 09:47 PM
Tymboo
Performance & Maintenance
11-13-06 08:44 PM
ozzie
GS - 1st Gen (1993-1997)
04-29-06 09:41 PM
Quick Reply: so I think I'm going to need a power steering pump soon.
