95 LS400 A/C Whines Bad
Old 04-06-03 | 05:35 PM
BrianV's Avatar
BrianV
Default 95 LS400 A/C Whines Bad
I have a 95 with 100K and it runs fine. The A/C works exceptionally well but when the compressor is on it whines linearally with the RPM. It is kind of annoying and definitely noticable, when it's off the engine is silent as can be.
I once had n Acura Integra that did the same thing.
Is there anything I can do to remedy this without replacing all the A/C components. I imagine it's the pump/ac motor which is something that sounds expensive.
What do you guys think?
Old 04-06-03 | 08:03 PM
SharpLS-96's Avatar
SharpLS-96
Sometimes that noise could also be related to a bad water pump (gears) that is about to go. I would check the water pump a.s.a.p.
Old 04-06-03 | 08:49 PM
tenpointed's Avatar
tenpointed
Banned
It sounds like the bearings may be wearing out in the compressor. Or the pulley may be going bad. Since the compressor still works, maybe you can have an a/c shop take a look at it before it seizes to avoid a very costly repair.
Old 04-08-03 | 06:25 AM
BrianV's Avatar
BrianV
It's only on when the a/c compressor is on. The second I turn the button off it goes off.
A lot of cars make this noise when the A/C is on, almost every car I've owned, maybe I just have bad luck. I'll have someone take a look at it.
lexixel
07-19-18 07:21 AM
justin1203
RX - 3rd Gen (2010-2015)
13
07-01-15 07:50 AM
DREGS3
Maintenance
12-01-11 07:45 PM
verylost
SC- 1st Gen (1992-2000)
14
06-26-02 06:28 PM
Quick Reply: 95 LS400 A/C Whines Bad
