96 lexus ls400
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/960x720/11889647_10153529788235406_3351809305463509981_n_d1e7ae924c90448903f87c62107e58f9e183f24d.jpg)
hi I have a 96 lexus ls 400 I just painted like 4 weeks then I just got a use transmission in my car and that was $1700 but what im tryin to say everytime I take it back to the shop they always tell me everything is fine with the car im sayin no it not I pick it up today drive it home then got ready for work it was smoking for under the car so I was like let me put some oil in the car cause I know its tyme for a oil change after I did that it was running fine but it look like now I have a oil leak now somewhere do u thank blue devil will work anyone PLEASE
punctuation is your friend... well apparently not yours lol
what makes you think oil is leaking? are there any puddles forming underneath the car while it's sitting? maybe it's tyme to take a look underneath the car and see if there's any fluids collecting anywhere
yea I just seen oil on the ground im at work right now and just went to go look under it im thinkin that when I got a oil change that they didn't plug it up right im going to take it for another oil change on Friday cause I have to drive from va to atl for a day 1st road trip in my car
Was the original paint all pealed off or what?
Since we can't see it, drive it, hear it, test it etc. etc. there is no way we can know what is going on with it.
We can guess at some things. And we need your help too.
Did you look under the car while it was parked to see where the oil was leaking? Is it engine oil? You need to tell us where the leak is in relation to the front tires front and back.
What color is the oil? Red is usually transmission fluid.
How was it loosing power? Did you push on the gas pedal and what happened? Did the engine just start slowing down? If so and oil leaking you really need to check the oil before driving it again.
A slipping transmission or a binding transmission can make it feel like loosing power. Even having your parking brake on or stuck calipers can do the same thing. Does the oil light on the cluster work okay?
So with the oil leak and new transmission it could be engine running with very little oil pressure or the transmission, or your brakes, parking brake etc. Is the check engine light on? If so get the code checked.
Elless400
15
10-27-17 12:16 PM
