It feels like the transmission jumps into neutral
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Hi! Lexus fellows,
This has happened to my 1991 LS_400, first generation in the past 6 months or so. And I have no control of when it may happen. I would have been cruising down the highway at 65 mph and suddenly the wheels lose power but speed did not drop, the RPM jumped to 3,000 or higher, and the engine roared. As the subject title says "It feels like the transmission jumps into neutral."
It happens not that frequently. I would say a couple times a week. I get out of it by switching on/off the overdrive, switching back and forth among neutral, D, and lower gears.
I should admit that the car did not do that when I first bought it three years ago. I live high on the hill and I started using the low gears to slow down when I go down hill. I wonder that has to do with the problem.
Just wondering if this has happened to anyone else?
Best Regards!
Vin
Best Regards!
Vin
is it just downshifting into 3rd? you said pressing the overdrive button and stuff makes it not do whatever its doing so maybe it's downshifting for some reason
This happened to me when I changed the trans fluid and underfilled it. Would randomly lose pressure and slip in and out of gear. Topped it off correctly and it is fine now. Check your levels according to the instructions in your manual.
Usually this happens when the level is not high enough and people may notice the problem.
In my case it needs to fill the ATF up to the high end marker or a bit more. Otherwise the car doesn't start properly in the morning.
Didn't you have any slow engagement problem when you put the AT lever to R or D?
DerekD1010
11-26-18 04:23 PM
LeapFrog
06-07-15 11:22 AM
Threxx
Performance
10-25-04 09:32 PM
