Cluster Change 90 to 93-94
Old 09-30-15, 05:06 AM
Najeeh
Najeeh's Avatar
Default Cluster Change 90 to 93-94
I was wondering if it is possible to change the cluster of the pre facelift ones that have the analog odometers to the ones which have the digital odometer. I have a right hand drive celsior and wanted to change from this:
to this:
Old 09-30-15, 12:20 PM
dicer
dicer's Avatar
The analog is a motor controlled deal. And not sure if it can be changed as there maybe other electronics updates on the newer ones that are not interchangeable. Someone here may know for sure.
Old 10-01-15, 07:11 AM
Najeeh
Najeeh's Avatar
I'll change the whole cluster with the bezel and the speedometer sensor. Are they are different for each type of cluster?
Old 10-01-15, 11:45 PM
cgawelko
cgawelko's Avatar
The thing with the early cluster - is that odometer. Its only semi-mech. It has all electrics behind it that tell the wheels to spin. Complete waste of engineering if you ask me. The harness will be totally different. So unless you wanna splice wires and connectors - you wont have much luck.
Old 10-02-15, 09:29 AM
Najeeh
Najeeh's Avatar
I don't want to cut the wiring harness. So i'll just find one analog odo cluster from a RHD model which goes to 260kph. Will the speedometer also need changing as mine only goes to 180kph
Old 10-02-15, 03:23 PM
cgawelko
cgawelko's Avatar
Its not analog - its semi-mech. The only mechanical parts are the little wheels in there that are all controlled by a small black electrical box.
Old 10-03-15, 05:47 AM
Najeeh
Najeeh's Avatar
so the bottom line is that the wiring harness at the back of the cluster is different for the digital odometers and the semi-mech ones.
Old 10-03-15, 08:02 AM
cgawelko
cgawelko's Avatar
There are 4 wiring juction plugs for the 93/94 cluster - the odometer and everything are all built into the main body - and there is one wiring harness connector at the very top for the check engine lights and stuff, then there is a white harness, blue harness, and orange harness that all plug side by side in the middle - so you would be wiring up a lot of stuff if you tried to change it out.
Old 10-03-15, 11:57 AM
Najeeh
Najeeh's Avatar
The thing is where I live, parts for this car are rare to find and if I do find one I have to make do with it. I'll see if I can get it to run
Old 10-04-15, 01:54 PM
dicer
dicer's Avatar
Then why not just keep what you have?
Old 10-05-15, 10:45 AM
Najeeh
Najeeh's Avatar
The current cluster has problems. The speedometer, trip and odometer are reading 4-5 times less than the actual speed. Like if the car is going 100 km/h the speedo will read 20 km/h. The trip meter when travelled 15-20 km will show that the car has travelled 3-4 km while the odometer shows the car has travelled 1km.
Also the tachometer sits below zero when the car is off. When I turn the key to ignition the needle rises a bit and when I start the car it shows 600 rpm. The needles are not stuck and tapping on the top of the cluster does nothing. The car is a 1990 Celsior which has done 168000 km (105000 miles).
Old 10-05-15, 11:45 AM
cgawelko
cgawelko's Avatar
The cluster needs rebuilt. there is a company in the vendor section that provides this service.
Old 10-05-15, 11:08 PM
MASTERkame
MASTERkame's Avatar
i think the main problem of his is the location where he lives at. Pakistan got same problem as most 3rd world countries like Lithuania any and many more. We don't have much of these car around. Scrapyards are also afraid of such cars to scrap. Because there is no profit when there is max to 10 of these car in whole country (at least in Lithuania there is from 5 to 10 of 95-98 models. and max 10 of 90+) He could try to send his cluster bus he would be without the car for 2 weeks or more and postage would rob him for 60 $ or even more to one side..
Old 10-06-15, 12:48 AM
cgawelko
cgawelko's Avatar
Isnt pakistan part of the UAE? One of the wealthiest regions there is? We had a badass LS400 sell in the group and get shipped over there. No expenses spared.
Old 10-06-15, 01:25 AM
MASTERkame
MASTERkame's Avatar
it is but it doesn't mean that its wealthy. For example Lithuania takes 141 place of poorest countries in the world from 184 which richest is QATAR with 184 place and Pakistan is just in 47 place. And we ain't rich in Lithuania as example average wage for the month is 600 $ and only 30% of population gets it. 55-65% lives for 380$ a month. But we got so many millioniers and even few billlioniers. Love what soviet union did to my country
so u can imagine how most of Pakistan people lives. And how much premium cars are there.
Quick Reply: Cluster Change 90 to 93-94
