Almost 100k Miles
So I am a couple hundred miles from reaching the big 100,000 miles on my 98 LS. What maintenance should I do?
I'm replacing the timing belt, I was wondering if there's anything else I should replace while the car is apart.
All normal parts that wear that the timing belt runs on and turns. Pulleys, water pump etc. also maybe thermostat, crusty hoses etc. it shouldn't need oil seals with low miles, but maybe you will want to do that too.
lserlohn
RX - 1st Gen (1999-2003)
06-09-15 05:58 PM
jgabem
09-15-10 10:01 PM
diamondmit
Maintenance
16
05-31-06 10:16 PM
