'93 LS400 noise comming from rear wheel
Old 10-15-15, 08:55 AM
sshhlexus
sshhlexus's Avatar
Default '93 LS400 noise comming from rear wheel
This has been happening on and off. Tires and brakes are okay. A garage a couple of weeks ago said it was one of the rear bearings. You hear a sound like you are coasting with steel wheels on a railroad track, again audible only on a quiet road.
Anyone know if this is okay to continue to drive with. Any what happens if or when it gets worse.
Thanks in advance.
Old 10-15-15, 12:30 PM
dicer
dicer's Avatar
Depends on how bad the noise is and how long its been going. Worse case it self destructs and then its metal on metal wear and can be a total axle and carrier replacement then.
Old 10-16-15, 11:59 AM
billydpowe
billydpowe's Avatar
hay rookie, get in there and find out what the problem is, fix it, you might be endangering someones life..
katg
03-30-11 05:24 PM
dedott21
03-08-08 08:50 PM
RL90LS400
Maintenance
09-12-02 12:51 PM
teddykrol
SC- 1st Gen (1992-2000)
10-07-01 11:21 AM
Quick Reply: '93 LS400 noise comming from rear wheel
