for anyone wondering what the muffler delete sounds like
Somebody can pop out of one of those intersections at any moment and the both of you would be dead.
You have no business being licensed to drive a car if you take part in stuff like that. Public roads are there for everyone to use safely.
Not maybe...it is crazy stupid. When you mature a little you'll understand that.
i know i'm not winning this battle so no point continuing and clogging up threads with needless back and forths. just know this doing this sort of thing is a rare occurrence, and i'm really pretty far from being a "menace"
Stroock, aside from the safety concerns... is this just the rear muffler delete? Since my original posting on it I have used it many times mostly when going to the drag strip to save weight and it NEVER sounds anywhere close to this loud. Once I pulled off the 2nd Y section from the middle resonator and it sounded like an open header Corvette. That said and to anyone wondering the in car sound is surprisingly quiet with only dropping the back 2 mufflers. It only takes about 10 minutes to remove them and then simply and easily re-install them. Simple to try for yourself. I have recommended to others if they like it to have a muffler shop bend simple 2.0" extensions to the rear bumper and if they like that they can add whatever chrome tips. This is by far the simplest, cheapest and lightest option vs. changing rear mufflers to add "sound" which is why I originally suggested this option. Really guys, if you want to know how it sounds simply try it. It is FREE.
whoa mr jbrady is here! i will def try this out as i already have the rear mufflers removed and think it's still too quiet. if i like the sound i'll add the piping extensions to the rear bumper. thanks for giving an example of what it can sound like. open header corvette eh...
Several things should be considered here. Removing mufflers and having the exhaust exit between the bottom of the car and the road causes the bottom of the car to act like a sound board and make the inside sound much louder. When I tried it the "Corvette" sound was my impression of the sound idling in the garage. On the road it was wicked loud and SLOWER.
If you deleted both the middle and rear mufflers and then ran 2.0" pipes to the back the sound would go down but to what degree I can only guess... never done that myself. YEARS ago I did this on a 5.7 liter V8, long tube headers, 18" straight through glasspack mufflers bolted to the header collectors and exiting between the road and the bottom of the car and it was LOUD. I had a muffler shop bend two 45 degree bends moving the outlets to side exits in front of the rear tires and it was MUCH better. This would be something cheap to try, remove the middle mufflers and have a shop make turnout side exits in front of the rear tires for testing. Some may like it. It would be aggressive and fairly to very loud.
For the record the image below is of the stock exhaust after the catalysts.
The sections include the front Y pipe and center resonator assembly, the rear Y pipe and middle mufflers assembly, the two rear mufflers and pipes.
and yea it's still pretty quiet inside. slight drone at like 55-65 and then you cant even really hear it above 70. above 3000 rpm the intake noise starts to overpower the exhaust and it's all you really hear, and it sounds awesome. then at like 5000 rpm you can hear the ACIS shortening the intake path, which to me sorta sounds a bit like vtec activating lol... there's like a sharp rise in pitch that you can hear. that intake design... great mod damn you now i want to take my remaining set of mufflers off and hear how it sounds lol
and thanks, i'm glad you like the wheels. honestly the car was really asking for it by having that redesigned more sporty front end but the wheels from a 1989 cadillac. luckily the LS looked mostly the same till the 460 so i think they work stylistically and look pretty stock.
