power window switch lights
Tried the search feature but had no luck.
1998 Ls400
at night the lights on my drivers door controls for the lock/unlock and windows is very dim. any idea whats causing this. Is it possible to replace bulbs inside?
thanks
1998 Ls400
thanks
LEDs are used for the light source. You can increase the brightness changing the series SMD register to a smaller resistance one if you are comfortable doing the SMD soldering job.
Thanks. But im not comfortable soldering. Sounds like there is a light source inside. But not something that is easily replaceable.
winter4w
10-11-16 03:21 PM
