Catalytic Converter needed
Have a 95 LS400 that I think has a bad catalytic converter, front passenger side. Also have another 95 I wrecked that I kept for parts. Problem is on the wrecked car the bolts are really corroded and I might not be able to remove them. If I go aftermarket for the CC, which is the best one for the money? Thanks for any help.
Have Kroil but used some other stuff first because I couldn't find the Kroil, have now found it, haven't tried heat yet. Can cut 4 of 5 bolts off, the 5th looks like It is impossible to get to to cut off. Which brand from Rock Auto?
on my 94, I used the cheapest ebay had to offer, passed inspection and never had a problem with them... so? sold it to a local man, later he gave it to his mom and I guess she is still driving it.....
Thanks men, I used a flow tester to check the CC's and they check out OK. Now think the problem is electrical. Changed out one of the coil packs and it worked great for a day and then started misfiring again. Am getting misfires from both coil pack banks, 3 on one side and 1 on the other. Changed the coil pack on the side with 3 cylinders misfiring. Might be the ECU. Plugs and wires changed 20K ago.
Walker;Purchased several months ago from rockauto and final cost was less than $100.00(after $50.00 rebate).No problems so far and annoying CEL went away.1997 LS400.
Bullochdaw
07-18-18 04:54 PM
