BBS Rims For 1990 LS400? Ideal rim and tire packs?
Hello everyone
No pun intended, but I do not want to reinvent the wheel here.
Any suggestions about where I can obtain a nice set of old school BBS basketweave rims for a 1990 lexus ls400? I would like to go from 15" stock to 16" or possibly 17". I know it is 5 lug pattern with 4.5" spacing, 50mm offset 15" x 6.5"
I would like to paint the centers some sort of grey or possibly gold on a cobalt blue metallic car.
any suggestions for tire size and rims? is something like this still available?
thanks a bunch
FL
thanks a bunch
FL
Original tire size is 205/65r15. That on a 6.5" wheel gives an overall diameter of 25.5". If you wanted to go up to 16s, you could probably find a 16x7 and put on a 205/60r16 and have a .2" greater diameter.... which is basically null.
As far as offset goes, if you want to keep the original fitment, you'll want to take away roughly 7 mm of offset for every half inch you add. The original 15x6.5 +50 wheel has a backspace of 145mm, while a 16x7 +43 has the exact same backspacing. And a 16x7.5 +36 still has the same backspacing. This will move the wheel outward slightly every time, giving you more of a lip or more of a concave depending on what kind of wheel you get, but the LS' have huge wheel wells. You should be able to fit nearly any 7" or 8" wheel with a medium/high offset.... lastly, since you have a UCF10. brake clearance shouldn't be an issue with any BBS wheel that I know of. The first gens didn't have very beefy brakes![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
As far as where to find old school BBS'.... that can be tricky. Ebay always has some, but you might be getting knockoffs.... I always order wheels through croooober. They offer worldwide shipping and have a ridiculous amount of aftermarket parts for insanely cheap. I picked up a set of 18" Work wheels for $450 with 4 day shipping straight from Japan, and a set of coilovers for about $400 that retail for $850 in the US. Good luck and show progress if you can!
SharkMark
06-06-13 06:15 PM
