Radiator options
Radiator options
Upper radiator plastic fitting collapsed and is now leaking. Is there an aftermarket option with all aluminum in/outlets? Is mishimoto an option? I see denso unit on rockauto for $100 shipped but would prefer all aluminum radiator.
please let us know what model radiator works for our cars. most radiators are all OEM spec plastic endtanks with metal cores.
http://www.ebay.com/itm/2-Row-Chevy-...aGpffw&vxp=mtr
Its more of a coolant reservoir/ expansion tank, than an overflow tank.
The first has a radiator cap and you add coolant to the system in it, and the later the coolant has to pass out through the radiator cap into the tank.
Part number for the Koyo OEM replacement is A1304
OEM Toyota part number 16400-50021
There is absolutely no reason to go with a solid metal radiator unless it is larger one, which you really only have to upgrade if you are overheating for some reason. The metal and plastic radiators tend to last long enough
