I've been having issues with my serpentines ripping apart. On further looking into the issue I noticed the belt is jumping off at the crank between the crank and tensioner. It either looks like the crank pulley is sitting back too far or the tensioner Is sitting far forward. Picture related. Is it possible for the crank pulley to shift backwards like that? Any advice or help please this is my only running vehicle.
Crank pulleys have a rubber compound built in the middle of them to dampen out the drive train. So they separate in the middle and wander in and out. Take the crank pulley off and take a look at it. It will be obvious what is wrong after you take it off. You might need an impact wrench to get it off.
Wow, just took a look online and they run around $250 or so. Not cheap- and you may have to google harmonic balancer to find it. My first try with crank pulley didn't work with amazon.
YES, your pulley has slipped look at this photo and see that the outer and inner pieces are flush, yours has moved backward.... this is very uncommon... a used one is recommended by me (but not everybody) EBAY 221934019786 70$ FREE SHIPPING..
belt squeaks? spray water on the belt..if it gets worse its a tensioner issue..if it gets more quiet its an alignment problem..no change then it could be an idler..alt..etc etc
Its a bad harmonic balancer- nothing else will help.
